kikiplus3 Posted August 15, 2016 Report Share Posted August 15, 2016 I have been having issues with my 09 Journey sxt 3.5L V6... It was overheating at one time seemed to have that under control NOW the coolant is leaving the resovoir but not leaking on the ground CHANGED: Thermostat a few times, , radiator, water pump, (might as well have ) timing belt, radiator cap.... the coolant seems to leave when the ac is has been used but every day the coolant has to be checked to make sure there is some in there.. Also its making a noise that's having me scratch my head cause she use to be on silent mode.... The noise almost sounds like a rattling coming from the passenger side. Any thought or suggestions? thanks dhh3 1 Quote Link to comment Share on other sites More sharing options...
2late4u Posted August 15, 2016 Report Share Posted August 15, 2016 check under your carpet for coolant leak from the heater core. dhh3 1 Quote Link to comment Share on other sites More sharing options...
kikiplus3 Posted August 15, 2016 Author Report Share Posted August 15, 2016 So far no leaking under carpet. That was checked as well as a friend suggested that too. Thank you for replying. I will continue to check that though. dhh3 1 Quote Link to comment Share on other sites More sharing options...
kikiplus3 Posted August 15, 2016 Author Report Share Posted August 15, 2016 dhh3 1 Quote Link to comment Share on other sites More sharing options...
Dusty256 Posted August 15, 2016 Report Share Posted August 15, 2016 time to get a preasure test kit . pump it up and look for a leak . if you are loosing that much you should see It . pin hole leak in the radiator and end caps kikiplus3 and dhh3 2 Quote Link to comment Share on other sites More sharing options...
kikiplus3 Posted August 15, 2016 Author Report Share Posted August 15, 2016 I will try this... thank you dhh3 1 Quote Link to comment Share on other sites More sharing options...
dhh3 Posted August 15, 2016 Report Share Posted August 15, 2016 Since you are adding coolant to the overflow tank, and it is not returning as it should; and, you mentioned overheating, you may have blown a head gasket. The coolant will be burned in the combustion chamber, and go out the exhaust pipe. If this is what is happening, you will never see a leak. I'd get a compression check on both cylinder heads. You have 24 valves, but only SOHC. Odd duck as most multi-valve engines are DOHC. Depending on how bad the gasket is blown, you may notice a decrease in power. Using the AC will make the engine work harder; therefore, more coolant will be lost through the head gasket. Depending on where it is blown, and on what side of the cylinder head, this problem could remain "as is" or slowly get worse. jkeaton, OhareFred and 2late4u 3 Quote Link to comment Share on other sites More sharing options...
bigtsr Posted August 15, 2016 Report Share Posted August 15, 2016 Do you see white smoke out the exhaust? Have an oil analysis done. jkeaton and dhh3 2 Quote Link to comment Share on other sites More sharing options...
kikiplus3 Posted August 15, 2016 Author Report Share Posted August 15, 2016 no white smoke Quote Link to comment Share on other sites More sharing options...
dhh3 Posted August 15, 2016 Report Share Posted August 15, 2016 (edited) Check your oil level. Is it higher than normal? How much coolant are you loosing each time you are checking it? If it is a small amount, the exhaust may not be white (steam) Edited August 15, 2016 by dhh3 Quote Link to comment Share on other sites More sharing options...
