redtomatoman Posted August 15, 2016 Report Share Posted August 15, 2016 I'm thinking about installing a towing hitch. I know very little about towing. My R/T does not have the towing package. I would like it to be fairly hidden as I don't like the look of some hitches that are very visible. Any suggestions for a hitch that is more subtle and hidden? Any pics would be appreciated. Thanks. Peace. dhh3 1 Quote Link to comment Share on other sites More sharing options...
2late4u Posted August 15, 2016 Report Share Posted August 15, 2016 check the forums, lots of info dhh3 1 Quote Link to comment Share on other sites More sharing options...
jkeaton Posted August 15, 2016 Report Share Posted August 15, 2016 If you type "trailer hitch" in the search bar, there are a lot of threads with pictures that will show up in the results. dhh3 1 Quote Link to comment Share on other sites More sharing options...
dhh3 Posted August 15, 2016 Report Share Posted August 15, 2016 I have the Mopar hitch as does Journeyman425. Mine is identical to his, and he has a picture of his on the forum. All of the DJs that I have seen with a hitch look like mine; the hitch bars are very visible. I think that they are designed this way because of the position of the spare tire. A little more room may have allowed for a "Hidden Hitch" where only the receiver is visible. The Trailer Tow Group only adds the engine oil cooler and a harness thrown into the back of the car. Look under your car and see if you have a harness with a bluish end, terminating between the back of the spare tire and the valence panel. The harness that the factory throws into the back of the car plugs into this bluish plug. For some reason my 3.6 came with the engine oil cooler and the harness which terminates behind the spare tire. I did not have the other harness with all of the relays hooked to it thrown into the back of the car. So, my window sticker did not show Trailer Tow Group. I found the harness and hitch on ebay, so now I basically have the Factory Trailer Tow Group. Journeyman425 added the TTG Sales Code for me. All my Dealer had to do was to install the harness with all the relays, the hitch, and active the Sales Code. jkeaton 1 Quote Link to comment Share on other sites More sharing options...
2xRustler Posted September 2, 2016 Report Share Posted September 2, 2016 The placement of the spare tire makes it impossible to hide the hitch. I have the Curt class 3 hitch and when I see one without it it looks wrong to me. From opening the box to putting my tools away was about 20 minutes. It really is not obtrusive and looks nice. If you are really concerned about it showing, take the sticker off when you put it on. Quote Link to comment Share on other sites More sharing options...
