DrewD707 Posted August 23, 2016 Report Share Posted August 23, 2016 P0302 2nd cylinder misfire rough idle... if my vehicle is having symptoms of this known cylinder head issue should dodge still be charging me for diagnostic?? Also what test should they Ben performing to check if this is the issue?? Anyone know if this is the cause for check engine light if they are required to get me a loaner for a fix they tell me will take a week..?? Thanks for any help dhh3 1 Quote Link to comment Share on other sites More sharing options...
redtomatoman Posted August 23, 2016 Report Share Posted August 23, 2016 PO302 is a misfire on cylinder 2. Could be the cylinder head or the cam phaser. Faulty head will fail compression testing. Refuse to pay for diagnosis if it's the cam phaser or cyl head. They are well known to Dodge. A good Dodge service center will provide a loaner. The job is about 12 hours of labor. Straight forward job for a competent technician. I've had both the phaser and left head replaced. Good luck. Peace. dhh3 1 Quote Link to comment Share on other sites More sharing options...
