Cableguy Posted August 31, 2016 Report Share Posted August 31, 2016 Just wondering if anyone out there knows how to retrieve OBD2 engines codes on a 2015 Journey without a scanner tool. I know the older Dodge and Chrysler vehicles had a procedure where you would turn the ignition key from off to on position three times and the code would show up on the odometer. Quote Link to comment Share on other sites More sharing options...
bigtsr Posted August 31, 2016 Report Share Posted August 31, 2016 The codes must be read by scanner on the DJ the old wiggle the key trick has not been valid for quite some time. The scanner will allow you to reset them also. Quote Link to comment Share on other sites More sharing options...
Cableguy Posted September 2, 2016 Author Report Share Posted September 2, 2016 Thanks for the information bigtsr. Quote Link to comment Share on other sites More sharing options...
