DonnyJerry Posted September 4, 2016 Report Share Posted September 4, 2016 My 2012 fwd has what seems to be well......common! When going over any sort of undulations in the road at low speed there is a pronounced "rubbery" sounding squeak in the front end. So far I have been able to rule out things like outer tie rod ends, sway bar links,ball joints. With the help of a buddy bouncing it I have been trying to "feel" for the noise by putting my hands on the various parts. It's seems to be coming from the passengers side and sounds like dry sway bar bushings. Though it don't sound like the noise is coming from there. More annoying than worrysome just worrysome enough to post here. Thanks in advance for any and all help! Quote Link to comment Share on other sites More sharing options...
Journeyphenia Posted September 5, 2016 Report Share Posted September 5, 2016 I had what I called a creaking sound on my 2015, over speed bumps and up driveways/sidewalks. The next time I had a tire rotation I sprayed silicone dry lube on all the moving parts of the passenger front wheel. It reduced it to almost 0 so whatever it is seems to be in one of the connecting components or bushings. My advice would be to give that a shot and see if it helps. Quote Link to comment Share on other sites More sharing options...
DonnyJerry Posted September 5, 2016 Author Report Share Posted September 5, 2016 Thanks for your reply I'll try your recommendation and post the results on here. By the way what product did you use and what parts did you spray precisely? Is this safe for such things as ABS sensors traction control hardware etc. Thanks again! Quote Link to comment Share on other sites More sharing options...
DonnyJerry Posted September 5, 2016 Author Report Share Posted September 5, 2016 Also if it's of any help it only seems to happen while turning left slowly such as when backing into your driveway and encountering a slight pothole Quote Link to comment Share on other sites More sharing options...
DonnyJerry Posted September 7, 2016 Author Report Share Posted September 7, 2016 Thanks Journeyphenia I followed your advice to the letter and the noise was completely eradicated! At a loss for what was actually making the noise but considering that all the critical parts are in good order who really cares! Thanks again! Quote Link to comment Share on other sites More sharing options...
JRodMTB Posted October 14, 2016 Report Share Posted October 14, 2016 Hit the lower control arm bushings, specifically with a good quality lubricant. It should eradicate the issue. Just for anyone reading this in the future JohnnyRevs and Ross_TO 2 Quote Link to comment Share on other sites More sharing options...
mschmu73 Posted February 10, 2020 Report Share Posted February 10, 2020 My 2013 had the same problem, front end noise going over bumps and thru dips for years. Brought it to my brother’s shop multiple times, and he changed bushings, control arm and sway bar. Problem still there. Last year when it was in his shop again he had the car in the air and happened to push up on the front end of the car. The whole thing was loose. He put some bolts in tightened it up and the noise is completely gone. Do yourself a favor and lift up up on the front end of your Journey, the would be bumper area, I bet it’s loose too. I told another Journey owner this and he thought I was crazy and didn’t want to believe it until he lifted up on his front end. You won’t see it by just looking. Check it out!! Quote Link to comment Share on other sites More sharing options...
Armando G Posted February 11, 2020 Report Share Posted February 11, 2020 @mschmu73 do you know where the bolts were installed? I've lubed mine in the past but the creaking has never really gone away. Quote Link to comment Share on other sites More sharing options...
mschmu73 Posted February 11, 2020 Report Share Posted February 11, 2020 My brother owns an automotive business and put it up in the air. I don’t know for sure because I didn’t see him fix it. May need someone to do that for you. I would guess it’s bolted to the frame. Worked like a charm. No more noises. Quote Link to comment Share on other sites More sharing options...
2late4u Posted February 12, 2020 Report Share Posted February 12, 2020 journeys dont have a frame, they are a unibody .style....... Rather than using a body placed around a separate frame, the frame and body in unibody vehicles are one single piece jkeaton 1 Quote Link to comment Share on other sites More sharing options...
Ross_TO Posted September 17, 2020 Report Share Posted September 17, 2020 On 10/14/2016 at 10:12 AM, JRodMTB said: Hit the lower control arm bushings, specifically with a good quality lubricant. It should eradicate the issue. Just for anyone reading this in the future Worked perfectly using Jig-A-Loo for me, thanks! Quote Link to comment Share on other sites More sharing options...
2late4u Posted September 17, 2020 Report Share Posted September 17, 2020 had to google it.....LOL Jig-a-Loo All Purpose Lubricant-10.9 oz Brand: Jig-A-Loo 4.2 out of 5 stars 16 ratings Amazon'sChoicefor "jig-a-loo" Price: $8.64 Sold on Amazon Quote Link to comment Share on other sites More sharing options...
John/Horace Posted September 17, 2020 Report Share Posted September 17, 2020 It’s possible subframe mounts that hold the engine/transmission frame against unibody needed tightening. Very large fastners and there is a rated torque spec. There would be 4 of them. Quote Link to comment Share on other sites More sharing options...
