Brake Squeak
kmac171
I just had to replace my front pad at 28,000mi, they were worn to NOTHING. I know it's not my driving habits because this has NEVER happened to me before. Anyway, I put ceramic pad on and now I have a squeal in the passenger from when I put the brakes on. I pulled the wheel off reseated the pads, took emery cloth to the rotor and nothing. It doesn't happen all the time, but about 90%. Any ideas??? Thanks.
Same here this car is nothing but trouble since I bought it 11 months ago in Sydney Australia, brakes squeals all the time and pads and rotors been replaced twice already it only lasted for 6 months .... its been in and out with the dealer with so many different issues and dealear said its normal ....so ready to bomb this piece of crap..am actually considering to trade this with Toyota Highlander/Kluger very soon.
they make a brake "gllue". you apply it to the back of the pads. The squeal is the pad vibrating against the caliper. This tacky stuff will dampen the vibration. I use it all the time. You put it on let it setup for about 5 to 10 mins. then install pads as normal. Semi Metallics squeal horrible. After application no noise.
