Backup Camera Wiring Harness
Hi Everyone
I just completed installing the 8.4" screen upgrade on my 2011 R/T (which when smoothly, and everything worked great)  and the place I purchased the center stack from gave me the back up camera from the same car.
My question: Is the harness available as a separate part, or can you only purchase it as a kit? I have done some research and found a part number for a 2014-2015, but I don't know if it would work with my 2011, or if it is even the correct part, and if it would be all I would need aside from the dealer activation. The part number I found is  68166537AC
Thanks in advance
According to FCA the video cabling is included in harnesses of later model Journeys, but not in early model ones.  The kits that FCA sells for the earlier Journeys includes the harness, among other things.  Having said that, I certainly could not find the rear connection points in my '14, so I did the work and ran the cable that came with my kit and the dealer made the connection to the radio when they added the sales code to enable the camera.
There is no part number in the instructions from the kit I bought, which was for '11 and '12 Journeys. Then again they don't provide the part numbers for ANY of the supplied components.
