Traction control light
mooley135
I was driving home tonight and the traction control and a red lightening bolt under the PRND display lit up and vehicle lost all power and was idling at 1800 rpms. Wouldn't take gas when you push the gas pedal. I shut it off waited about 30 seconds, started it and it was fine. 5 miles down the road it did it again. Any ideas? Is it electronic or a mechanical problem?
Disconnecting the battery for 15 - 20 minutes resets the CanBus computer
network which controls all the primary functions in the DJ , it may resolve
electrical faults/gremlins but not always.
A bad battery causes many weird faults on todays computer controlled vehicles
that is why it should be load tested as part of fault finding particularly if you
don't know how long it has been in service.
If you goto FCA Chrysler website you can enter your VIN# and if there are recalls
outstanding it may well tell you but a dealer must do the work irregardless.
