TPMS dash light will not reset
Crf2mom
Belt inside the front tire broke causing the car the shake terribly while driving and the tire sensor on the dash wasn't registering the tire at all. Only showed two dashes instead of a psi reading. Replaced the tire but the diagram on the dash still isn't registering. Is there a quick fix I can do myself to reset it?
There is no 'reset' for the TPMS.  It is a dynamic system.  So either the sensor is bad (dead battery or shaken to death) and needs to be replaced or the pickup antenna for that wheel is bad or disconnected.  To determine which without using the special and expensive diagnostic tool, rotate your tires to see whether the problem moves with the wheel or stays with the location.
Note that when changing tires on the Journey, unless the other tire(s) is(are) new, they must be changed in pairs if you have FWD, or all four if you have AWD because of the TCS and AWD control system.
Edited by bramfrank
