Dodge 2010 Posted November 3, 2016 Report Share Posted November 3, 2016 while I'm on the road the battery sing turn on on my dodge journey 2010 SE Dashboard, what will be the solution? Quote Link to comment Share on other sites More sharing options...
Dusty256 Posted November 3, 2016 Report Share Posted November 3, 2016 Your journey is not charging the. .battery most likely the alternator is bad .. easy to check by by stopping at parts store near you have them test it . one note, if you replace the alternator be sure to fully charge the with a battery charger first as it will be easier on the new alternator jkeaton and 2late4u 2 Quote Link to comment Share on other sites More sharing options...
jkeaton Posted November 3, 2016 Report Share Posted November 3, 2016 1 hour ago, Dodge 2010 said: while I'm on the road the battery sing turn on on my dodge journey 2010 SE Dashboard, what will be the solution? Get you battery and alternator checked. 2late4u 1 Quote Link to comment Share on other sites More sharing options...
2late4u Posted November 3, 2016 Report Share Posted November 3, 2016 like jkeaton said get it checked. Most auto stores auto zone , advance auto. will check them both for free. has the battery been changed or is it the org one? check all your connections and wires for any problems or as dusty265 says it could be the alt. either way good luck jkeaton 1 Quote Link to comment Share on other sites More sharing options...
Dodge 2010 Posted November 3, 2016 Author Report Share Posted November 3, 2016 Thanks all for the great advice Quote Link to comment Share on other sites More sharing options...
