TheseJeans Posted November 10, 2016 Report Share Posted November 10, 2016 (edited) My 8.4 uconnect, no Navi, is having behavior issues! I started my car a few weeks ago and as soon as the screen came up it faded away. It does this every 10 seconds, it affects my radio which turns off for a few seconds. If I have my phone playing music via Bluetooth or aux, or a CD in, it restarts the song over every 10 seconds. It comes up with the dodge screen but not the screen with the warning that comes on when starting the car. My USB also stops charging my phone every 10 seconds unless I have it plugged into the USB in the backseat. I was thinking a fuse issue maybe or an update is needed. I installed the update and while installing on that screen, it didn't reboot. The screen stayed on the entire time which was very promising but as soon as the update was done and it was back to the red/black uconnect screen it started rebooting every 10 second again. This tells me it's not a hardware problem but a software problem. I've tried going into the menu where you can factory reset but I can't get to that menu. Any ideas what could be causing this? I'm really trying not to take it to the dealership! TIA Edited November 10, 2016 by TheseJeans Spelling mistake in title Quote Link to comment Share on other sites More sharing options...
TheseJeans Posted November 10, 2016 Author Report Share Posted November 10, 2016 On 11/10/2016 at 3:09 AM, TheseJeans said: My 8.4 uconnect, no Navi, is having behavior issues! I started my car a few weeks ago and as soon as the screen came up it faded away. It does this every 10 seconds, it affects my radio which turns off for a few seconds. If I have my phone playing music via Bluetooth or aux, or a CD in, it restarts the song over every 10 seconds. It comes up with the dodge screen but not the screen with the warning that comes on when starting the car. My USB also stops charging my phone every 10 seconds unless I have it plugged into the USB in the backseat. I was thinking a fuse issue maybe or an update is needed. I installed the update and while installing on that screen, it didn't reboot. The screen stayed on the entire time which was very promising but as soon as the update was done and it was back to the red/black uconnect screen it started rebooting every 10 second again. This tells me it's not a hardware problem but a software problem. I've tried going into the menu where you can factory reset but I can't get to that menu. Any ideas what could be causing this? I'm really trying not to take it to the dealership! TIA Expand Also, I'd like to try disconnecting the battery but I've read that I may need an anti theft code after...true? Quote Link to comment Share on other sites More sharing options...
yyz Posted November 10, 2016 Report Share Posted November 10, 2016 If you are under warranty I don't know why you wouldn't take it in to the dealership. I can't really see a software issue that was there before and after you did an upgrade. jkeaton 1 Quote Link to comment Share on other sites More sharing options...
TheseJeans Posted November 10, 2016 Author Report Share Posted November 10, 2016 I called the dealership and I'm over 60k so the radio is not under warranty anymore. This issue happened 2 weeks after getting the Journey so I'm not interested in paying a few hundred $$ if it's something I can fix myself. It can't be a hardware issue or else the hardware would have been malfunctioning while the upgrade was taking place. Quote Link to comment Share on other sites More sharing options...
yyz Posted November 11, 2016 Report Share Posted November 11, 2016 Why can't it be hardware?It could be something used by the radio in normal operation but is not used when doing a software upgrade which technically the radio is in data receive mode .Assume you have the same software 1000's of people have and they don't have this problem tells me it's a hardware issue. Quote Link to comment Share on other sites More sharing options...
TheseJeans Posted November 12, 2016 Author Report Share Posted November 12, 2016 On 11/11/2016 at 12:06 AM, yyz said: Why can't it be hardware?It could be something used by the radio in normal operation but is not used when doing a software upgrade which technically the radio is in data receive mode .Assume you have the same software 1000's of people have and they don't have this problem tells me it's a hardware issue. Expand Ok, so today I plugged in my iPad to charge and it recognized it as an iPod and started playing music from it without it blacking out. I tried satellite radio and normal radio and they were all working. It seems that when I have something plugged into the middle console USB the uconnect works. If I disconnect the charger from the iPad but not the console it starts blacking out again. Weird. Any ideas? Quote Link to comment Share on other sites More sharing options...
