Devilzblood Posted November 25, 2016 Report Share Posted November 25, 2016 Hi, I know its not advisable to install HID's in a Halogen projector as it degrades it over time. What about installing a good quality LED Bulb? Since the heat from LED is far lower then HID, would that help prolong the life of the projectors? Thank you! Quote Link to comment Share on other sites More sharing options...
Devilzblood Posted December 3, 2016 Author Report Share Posted December 3, 2016 No one? Quote Link to comment Share on other sites More sharing options...
bramfrank Posted December 3, 2016 Report Share Posted December 3, 2016 Heat is not the issue - blinding oncoming traffic is. If you must up the output of the stock reflectors buy HIR bulbs. Quote Link to comment Share on other sites More sharing options...
Devilzblood Posted December 5, 2016 Author Report Share Posted December 5, 2016 (edited) On 12/3/2016 at 4:03 PM, bramfrank said: Heat is not the issue - blinding oncoming traffic is. If you must up the output of the stock reflectors buy HIR bulbs. Expand So My question was LED bulbs in Halogen Projectors not reflectors Edited December 5, 2016 by Devilzblood Quote Link to comment Share on other sites More sharing options...
vozaday Posted December 19, 2016 Report Share Posted December 19, 2016 Watch this video and you will see why LEDS do not perform properly in a projector. HIDs in a lot of halogen projectors do indeed work well, it is hit or miss though. Some have horrible glare, but some contain it very well. jkeaton 1 Quote Link to comment Share on other sites More sharing options...
Cody Chornobey Powley Posted December 28, 2016 Report Share Posted December 28, 2016 Hid bulbs are designed specifically for hid bowls. Doesn't matter if the halogen projector hides glare well or not.....if you look at a vehicle with halogen projectors and hid projectors you'll see a noticeable difference in he size of the bowl to reduce a fire from burning the bowl......makes sense right...either. Buy hid projectors or risk a fire by putting a bulb that hot in such a small space jkeaton 1 Quote Link to comment Share on other sites More sharing options...
bramfrank Posted December 28, 2016 Report Share Posted December 28, 2016 Just buy HIR bulbs and while they may not be diamond white, they will be almost twice as bright as OEM with no side effects and the bulbs should last a lot longer than overpriced, overhyped dyed lights like the PIAA and other competitors. jkeaton 1 Quote Link to comment Share on other sites More sharing options...
