weasey31 Posted December 14, 2016 Report Share Posted December 14, 2016 (edited) Weather temp: 30F The other morning tried to start the DJ. It wouldn't start, so I jumpstarted it like so many other times before . After it warmed up, I proceeded to drive down the road. The ESP idiot light was on and would not turn off. My throttle was limited to 2000 rpm. Nothing faster. I managed to drive it down to the dodge dealer going a max of 10 mph, thinking something was wrong with the engine. when I got there my wife is waiting for me I said hold on let me try to shut the car off and restart it again to see if it goes back to normal. So I did. After I restarted it I drove around the block to test the engine power and it was at full power. I think the electronic throttle-control was tripped or the computer put it in a limited engine power condition. has anybody experienced this? After what I thought is major money problem was no problem at all but something I'd never experienced before. The battery voltage must of been extremely low and caused the computer to control the engine in a restricted fashion. Edited December 14, 2016 by weasey31 Added thoughts Quote Link to comment Share on other sites More sharing options...
bigtsr Posted December 14, 2016 Report Share Posted December 14, 2016 How old is your DJs battery? Quote Link to comment Share on other sites More sharing options...
Camper Posted December 14, 2016 Report Share Posted December 14, 2016 I do have same problem before, here it is from my one of the post:""""" Returning home from long trip and on last Sunday, got ""check engine light"" on my 2016 Journey (22000 km), connected the scanner and get the following error:"""P084b-Transmission Fluid Pressure Sensor/Switch H Circuit Range/Performance"", Transmission stuck in one gear and do not changed it went to "limp" mode, however it goes to reverse as well.. So I can go 60 km/h on 4000rpm. Dropped car to dealer and get "Valve Body" replaced, everything done under warranty. On my previous Journey-2012 (161000 km) never have this problem.""""". Hope this help Quote Link to comment Share on other sites More sharing options...
weasey31 Posted December 15, 2016 Author Report Share Posted December 15, 2016 On 12/14/2016 at 7:46 PM, bigtsr said: How old is your DJs battery? Expand I have to check. Good question. It's cold out and the battery is hidden in the fender so I'm not in any hurry to check it. I will check soon though and report back Quote Link to comment Share on other sites More sharing options...
weasey31 Posted December 15, 2016 Author Report Share Posted December 15, 2016 On 12/14/2016 at 10:43 PM, Camper said: Are you saying you experienced the limited engine power mode @ 4000rpm and not a revolution over? Expand Quote Link to comment Share on other sites More sharing options...
Camper Posted December 15, 2016 Report Share Posted December 15, 2016 No, what I am say, I can push rpm up to 4000, however, the car do not change the gear, it stay on first one, so on that rpm I can push speed up to 60 km/h Quote Link to comment Share on other sites More sharing options...
