journey325 Posted December 23, 2016 Report Share Posted December 23, 2016 (edited) Hi All can any body help. I took my dj for a MOT and was told the hand brake was not working properly.so I put new pads on thinking that would sort the problem as I have done on many other cars. But this time it's made no difference, both hand brake cables and calipers are moving as they should but the caliper piston is not moving as they should, I've tried all sorts to get them to work, even stripped the done, also I'm in the UK and nobody stocks these calipers apart from the main dealers Edited December 23, 2016 by journey325 To add more content Quote Link to comment Share on other sites More sharing options...
OhareFred Posted December 23, 2016 Report Share Posted December 23, 2016 Did you use a brake tool and turn the rear pistons in, not just compress them? If you just compressed the rear pistons in they are damaged and you'll need to replace the rear calipers. jkeaton 1 Quote Link to comment Share on other sites More sharing options...
journey325 Posted December 23, 2016 Author Report Share Posted December 23, 2016 Hi, yes I did use the brake winding in tool, but the pistons don't seem to move when you operate the handbrake lever Quote Link to comment Share on other sites More sharing options...
OhareFred Posted December 23, 2016 Report Share Posted December 23, 2016 The pistons move when you apply the brakes, but not the parking brake? I would start looking at the cables. Something may have broken off and the cable is not connected to the rear brakes anymore. 2late4u 1 Quote Link to comment Share on other sites More sharing options...
