cnaber Posted January 8, 2017 Report Share Posted January 8, 2017 Just bought a 14 journey sxt and put an astro start system in it with the t-harness (plug and play) with the d-600 module. Had some issues flashing the module but eventually it took. here is my problem, the remotes work, they light up the dash, lock and unlock the car, and will turn off the car. the issue is it will not START the car. it says no key detected on the dash, turn off the lights and tries again. if you are sitting in the car with the key, it will start. tried taking the battery out of the factory FOB, PTS started vehicle with fob, got out and turned it off the the astro start remote. still will not start, no key detected. anyone encountered this problem? one tech said it did not clone the key code to detect the key. is there some step we missed or do we need more parts? ASAP fix much welcomed, its cold in Minnesota! Quote Link to comment Share on other sites More sharing options...
2late4u Posted January 8, 2017 Report Share Posted January 8, 2017 my guess you need to get in touch with the tech support from the company that sold you this product, but welcome to the group.. jkeaton 1 Quote Link to comment Share on other sites More sharing options...
jkeaton Posted January 8, 2017 Report Share Posted January 8, 2017 It's difficult to integrate anything aftermarket into the canbus vehicles. As stated, you might be better off contacting the company. Quote Link to comment Share on other sites More sharing options...
larryl Posted January 8, 2017 Report Share Posted January 8, 2017 or getting an oem installed by the dealer jkeaton 1 Quote Link to comment Share on other sites More sharing options...
wpginterceptor Posted March 12, 2017 Report Share Posted March 12, 2017 (edited) I'm having this same problem.. did you figure it out! you are also running a ADSTB module correct? Edited March 14, 2017 by wpginterceptor Quote Link to comment Share on other sites More sharing options...
