2011 journey mainstreet rear brake job
Hello,
I need opinion about 2011 mainstreet rear brakes.  I need to replace pads and rotors.  I am not going to buy OEM since they are wearing out too quickly.
Should I buy Ceramic or Semi-metallic?  The price is about same and warranty is also lifetime limited on both.
Normally I would do brake pads myself but since rotors are involved, I will be paying 50 bucks for rear job which is not too bad.  So if pads run out say in 30K miles, I will replace myself so it won't cost me more than my time.
So bottom line question:  Ceramic pads or Semi-metallic?  If any brand besides OEM, I will consider them also but most likely will just get mid-grade from auto parts store or amazon or ebay motors.
Thank you!
5 hours ago, patelajit said:
Hello,
Thank you!
so is he going to turn your rotors as $50 for a brake job is a hell of a deal as the pads will cost you at least $30-50 and turning rotors usually cost about $10 each?
