Good luck with part numbers, they're all over the map and there's no magic decoder ring.  Often even the sellers have no clue what they are offering - one member here bought THREE different radios from three DIFFERENT vendors and NONE of the three had nav even though they all claimed theirs did.
You can use any RB5 from any vehicle except the Dart.  So the 300, Charger and Journey can be donor vehicles if you get the right years.  There are 3 series of RB5 . . . the original, which is from 2011 to mid 2012, another from mid 2012 to mid 2013 and 2014 and later radios, the latter of which support satellite traffic.  All 2012+ and later radios as well as updated 2011's need an unlock code.
Since you have a Crossroad you have an RE2 with SiriusXM so you have the antenna already.
The swap takes all of 5 minutes once you have all the components in place.
I have a 2014 radio I've tested sitting on my shelf available for purchase . . . . it is listed in the classified section.
guess he means......
"OEM" redirects here. For other uses, see OEM (disambiguation).
An original equipment manufacturer (OEM) is a company that makes a part or subsystem that is used in another company's end product.[1] For example, if Acme Manufacturing Co. makes power cords that are used on IBM computers, Acme is an OEM.
However, the term is used in several other ways, which causes ambiguity. It sometimes means the maker of a system that includes other companies' subsystems, an end-product producer, an automotive part that is manufactured by the same company that produced the original part used in the automobile's assembly, or a value-added reseller.[2][3][4]
Ok, I got an RB5 from a 2014 DJ. Cant wait for my 16 to have NAV and XM Traffic. You guys are a plethora of Info!!! Hope fully when received I can get the unlock key quickly. I hate waiting. lol I think in going to order the lock pick? if that's what its called. I hate the fact that you cant change nav info on the fly. What if a passenger wants do do it?
