RICW Posted January 31, 2017 Report Share Posted January 31, 2017 I hope I'm in the right area. MY 12 RT gauges , speedo, radio shut down, fan defaults to high defrost, power windows quit, service drive etc. and sometimes clears and runs ok. Just came from dealer and they reset the tipm and problem was not resolved. Any help would be appreciated. Quote Link to comment Share on other sites More sharing options...
OhareFred Posted January 31, 2017 Report Share Posted January 31, 2017 Does it trip any codes? Sounds like the dash cluster or bcm.... Quote Link to comment Share on other sites More sharing options...
jkeaton Posted January 31, 2017 Report Share Posted January 31, 2017 How is the battery and connections? Try disconnecting the battery for a bit to reset it again and have your charging system tested. Most autoparts stores can load test the battery for you. 2late4u 1 Quote Link to comment Share on other sites More sharing options...
bigtsr Posted January 31, 2017 Report Share Posted January 31, 2017 Have the battery load tested. It's a 2012 so may have been installed 2011 and batteries in Mopars typically last 4 - 6 years if you have a good one. When things get erratic that should be the first assumption. Quote Link to comment Share on other sites More sharing options...
2late4u Posted January 31, 2017 Report Share Posted January 31, 2017 i dont take chances with mopar batteries i just changed out my 2014 battery nothing wrong as far as i knew but my daughter needed one for her back up mail vehicle as hers went dead so swapped them out for her and a new one for me ,all set for a couple of years now i hope......if your journey is acting erratically change the battery out its at least 4-5 yrs old if its the org. one. Quote Link to comment Share on other sites More sharing options...
RICW Posted January 31, 2017 Author Report Share Posted January 31, 2017 Brought it to dealer yesterday and it of course would not act up for them . Battery was replaced in September and tested fine. No codes showed up On way home after their hours speedo went out, windows inop, fan to high defrost, no uconnect screen, battery light, ck engine light, and loss of speed. If I pull over, and restart then sometimes it starts to function ok. Quote Link to comment Share on other sites More sharing options...
larryl Posted February 1, 2017 Report Share Posted February 1, 2017 You should take pictures or video with your cell phone if you have one when its acting up then you have proof jkeaton, OhareFred and Trains123 3 Quote Link to comment Share on other sites More sharing options...
RICW Posted February 22, 2017 Author Report Share Posted February 22, 2017 dealer replaced the ecm and tipm today, and problem not corrected. Quote Link to comment Share on other sites More sharing options...
bramfrank Posted February 22, 2017 Report Share Posted February 22, 2017 As long as you aren't paying for his thrashing about . . . . . jkeaton 1 Quote Link to comment Share on other sites More sharing options...
