Topher40 Posted February 2, 2017 Report Share Posted February 2, 2017 I have 2011 Dodge Journey Mainstreet and I'm running into an issue that I've seen on this forum. 3 lights on all the time. From reading, it seems to be a wheel speed sensor. My questions are, do I access the sensor through the floor board as it comes through a hole inside the vehicle, or on the outside where a typical WSS would be? If found on the inside, I have already pulled the rear passenger seat, do I pull the carpet and it magically appears, or do I have to pull the paneling off to get to it? Thank you for any feedback as I'm learning as I go Quote Link to comment Share on other sites More sharing options...
jkeaton Posted February 3, 2017 Report Share Posted February 3, 2017 Wheel speed sensors are on the wheel hub. Quote Link to comment Share on other sites More sharing options...
