RickLogan Posted February 27, 2017 Report Share Posted February 27, 2017 Ok, I'm back.............replaced the Camshaft sensor, drove ti work (about 60 miles) on my way home, the light came on again, and the traction control light as well, P0344 is the code. It drives fine, except it won't sift into 6th gear, but I can manually shift, and it runs fine. What should I be looking for at this point? Quote Link to comment Share on other sites More sharing options...
jkeaton Posted February 27, 2017 Report Share Posted February 27, 2017 Did you use OEM parts? Quote Link to comment Share on other sites More sharing options...
RickLogan Posted February 27, 2017 Author Report Share Posted February 27, 2017 27 minutes ago, jkeaton said: Did you use OEM parts? No, that's my next step, I have one on order from the dealership Quote Link to comment Share on other sites More sharing options...
jkeaton Posted February 27, 2017 Report Share Posted February 27, 2017 Since it's the same code, that's where I'd start. Using OEM parts. RickLogan 1 Quote Link to comment Share on other sites More sharing options...
RickLogan Posted February 28, 2017 Author Report Share Posted February 28, 2017 17 hours ago, jkeaton said: Since it's the same code, that's where I'd start. Using OEM parts. While I am waiting for the part, would you happen to know why the traction control shuts off at the same time? Quote Link to comment Share on other sites More sharing options...
jkeaton Posted February 28, 2017 Report Share Posted February 28, 2017 Probably any check engine light shuts off TC, ABS, etc. Quote Link to comment Share on other sites More sharing options...
RickLogan Posted February 28, 2017 Author Report Share Posted February 28, 2017 10 minutes ago, jkeaton said: Probably any check engine light shuts off TC, ABS, etc. Ok thanks. Quote Link to comment Share on other sites More sharing options...
RickLogan Posted March 9, 2017 Author Report Share Posted March 9, 2017 Ok, so I got the new OEM sensor, and installed it, was working great for about 600 miles, then the P0344 came back Any more ideas? Quote Link to comment Share on other sites More sharing options...
RickLogan Posted March 13, 2017 Author Report Share Posted March 13, 2017 Anyone? Quote Link to comment Share on other sites More sharing options...
OhareFred Posted March 13, 2017 Report Share Posted March 13, 2017 Im sure its being read, just no idea what to tell ya... jkeaton 1 Quote Link to comment Share on other sites More sharing options...
