Dakotawhite Posted February 28, 2017 Report Share Posted February 28, 2017 Hey, so I apologize if this has already been posted but I've run into an issue where my driver side brake light keeps going out. I've had the car for about 2 years now and this will be the third time I've had to replace it. I've never even had to replace the passenger side so something is wrong. Any suggestions would be helpful. Thanks. Quote Link to comment Share on other sites More sharing options...
2late4u Posted February 28, 2017 Report Share Posted February 28, 2017 havent had any problems with mine and havent really read anything on here about bulbs going bad check your wiring the best you can maybe a stripped wire maybe a water leak good luck Quote Link to comment Share on other sites More sharing options...
OhareFred Posted February 28, 2017 Report Share Posted February 28, 2017 Check for a bad ground and inside the connector for corrosion 2late4u 1 Quote Link to comment Share on other sites More sharing options...
