TrypWyr Posted March 26, 2017 Report Share Posted March 26, 2017 (edited) We purchased a used fleet vehicle, 2014 Journey Limited. I see nothing on the original window paper about towing. We are looking into purchasing a pop-up camper (Flagstaff 206LTD, GVWR 2274) but I need to get a hitch and harness installed. After reading on these forums I'm concerned that this vehicle needs more than just the physical hitch but also re-programming and possibly an add-on engine cooler? Any advice would be greatly appreciated! EDIT: So it looks like I already have the engine oil cooler, according to my VIN-specific equipment listing. My understanding is that the transmission cooler is standard. I'm thinking at this point that the Curt class III along with the wiring harness and a possible flash of the computer and I should be good to go. Edited March 26, 2017 by TrypWyr Add info km-04 1 Quote Link to comment Share on other sites More sharing options...
larryl Posted March 26, 2017 Report Share Posted March 26, 2017 4 or 6cyl? The build code should tell you if it has the towing option which included the cooler and harness? If it did then you buy the hitch and its an easy install but the dealer may need to flash the computer. A 4cyl engine will work much harder than the 6 km-04 1 Quote Link to comment Share on other sites More sharing options...
jkeaton Posted March 26, 2017 Report Share Posted March 26, 2017 2274 is pushing the tow limit. km-04 1 Quote Link to comment Share on other sites More sharing options...
TrypWyr Posted March 26, 2017 Author Report Share Posted March 26, 2017 3.6L 6-cylinder, AWD. Nothing in the build listing shows anything for towing, but the added optional equipment for my VIN shows the engine oil cooler and "trailer sway damping". The 2274 is the max weight for the trailer, the actual unloaded weight is 1608. We don't plan on packing much in it and won't be using the fresh water tank (at least on the first road trip, we will mostly be sticking to parks with hookups). km-04 1 Quote Link to comment Share on other sites More sharing options...
2late4u Posted March 26, 2017 Report Share Posted March 26, 2017 i think if you use the curt electrical wiring kit you wont have to get it flashed at the dealership and the curt hitch goes on easy. km-04 1 Quote Link to comment Share on other sites More sharing options...
Armando G Posted August 3, 2017 Report Share Posted August 3, 2017 On 3/26/2017 at 1:42 PM, TrypWyr said: 3.6L 6-cylinder, AWD. Nothing in the build listing shows anything for towing, but the added optional equipment for my VIN shows the engine oil cooler and "trailer sway damping". The 2274 is the max weight for the trailer, the actual unloaded weight is 1608. We don't plan on packing much in it and won't be using the fresh water tank (at least on the first road trip, we will mostly be sticking to parks with hookups). Curious if you ever got your hitch installed, and if it worked out for the trailer you were thinking? Installed the Curt hitch and wiring harness on mine and worked out great. Did have to get a receiver with a 2.5" lift in order for the hitch to be level for your average trailer. It seems that the hitch on the DJ is a little low. km-04 1 Quote Link to comment Share on other sites More sharing options...
km-04 Posted August 3, 2017 Report Share Posted August 3, 2017 (edited) Sorry for the silly question, but why would you need to flash the vehicle after adding a tow hitch? I was thinking of maybe adding a hitch to my 2014 SE. Edited August 3, 2017 by km-04 Quote Link to comment Share on other sites More sharing options...
jkeaton Posted August 3, 2017 Report Share Posted August 3, 2017 You need to enable the wiring harness to power the trailer lights,. km-04 1 Quote Link to comment Share on other sites More sharing options...
km-04 Posted August 3, 2017 Report Share Posted August 3, 2017 30 minutes ago, jkeaton said: You need to enable the wiring harness to power the trailer lights,. Thanks. You would think it would already be enabled. Why would the manufacturer/dealer disable it? Is it to make money enabling it? Quote Link to comment Share on other sites More sharing options...
jkeaton Posted August 3, 2017 Report Share Posted August 3, 2017 16 minutes ago, km-04 said: Thanks. You would think it would already be enabled. Why would the manufacturer/dealer disable it? Is it to make money enabling it? Probably. I cannot answer that question. km-04 1 Quote Link to comment Share on other sites More sharing options...
km-04 Posted August 3, 2017 Report Share Posted August 3, 2017 2 hours ago, jkeaton said: Probably. I cannot answer that question. Thanks for the insight provided. Quote Link to comment Share on other sites More sharing options...
2late4u Posted August 3, 2017 Report Share Posted August 3, 2017 3 hours ago, km-04 said: Thanks for the insight provided. if you use the factory wiring you will have to have it flashed at the dealership....if you use the curt wiring kit that is all you have to do. km-04 and jkeaton 2 Quote Link to comment Share on other sites More sharing options...
km-04 Posted August 4, 2017 Report Share Posted August 4, 2017 12 hours ago, 2late4u said: if you use the factory wiring you will have to have it flashed at the dealership....if you use the curt wiring kit that is all you have to do. So the curt wiring bypasses the need for flashing, correct? How much more is the curt wiring than the factory? Quote Link to comment Share on other sites More sharing options...
2late4u Posted August 4, 2017 Report Share Posted August 4, 2017 2 hours ago, km-04 said: So the curt wiring bypasses the need for flashing, correct? How much more is the curt wiring than the factory? yes... just google curt hitches and determine if you have reg or led taillights then order it will cost you less than the factory... there are videos on youtube showing how to install the wiring.... km-04, jkeaton and Bryman31 1 2 Quote Link to comment Share on other sites More sharing options...
km-04 Posted August 4, 2017 Report Share Posted August 4, 2017 3 hours ago, 2late4u said: yes... just google curt hitches and determine if you have reg or led taillights then order it will cost you less than the factory... there are videos on youtube showing how to install the wiring.... Thanks. Quote Link to comment Share on other sites More sharing options...
Armando G Posted August 5, 2017 Report Share Posted August 5, 2017 Curt hitch packaged with the receiver, ball, and wiring kit is the way to go. Ebay has the package deal for under $190 and installation is easy (if you have at least basic car skills). I installed my hitch and wiring harness by myself without even having to jack it up. Just keep in mind that you will most likely use the receiver in the 'rise' position since the hitch sits a little low. I would of loved to use the pre-installed harness (connector was $80), but the 2 dealers I went to couldn't figure out if they would be able to flash my specific car. I was told to buy the harness and then they would give it a try. I could then return the harness if it didn't work, minus the restocking fee. Finally decided to go with the Curt wiring harness and it works like a charm. jkeaton 1 Quote Link to comment Share on other sites More sharing options...
