Roger-Dodger Posted March 31, 2017 Report Share Posted March 31, 2017 Greetings... I was told by a local garage mechanic NOT to use a battery tester on my 2014 Journey. He said it would damage the electrical system and computer. I've been using an inexpensive 100 amp battery load tester from Harbor Freight on my older Chrysler products with no problem. I'm mainly interested in the 'Cold Cranking Amps' up here in snow country. Got any opinions about using it on my Journey...??? Thanks >> (My tester is the type that heats up a coil until it glows like a toaster.) Roger >> Quote Link to comment Share on other sites More sharing options...
jkeaton Posted March 31, 2017 Report Share Posted March 31, 2017 Never used one. Hopefully someone will answer. Quote Link to comment Share on other sites More sharing options...
OhareFred Posted March 31, 2017 Report Share Posted March 31, 2017 Well. Go direct to the battery terminals, not the jump points, and I would think you would be ok. if you are really concerned, take the batterycables off. Quote Link to comment Share on other sites More sharing options...
larryl Posted March 31, 2017 Report Share Posted March 31, 2017 I have used one on my 13 no issue Quote Link to comment Share on other sites More sharing options...
Hankster Posted March 31, 2017 Report Share Posted March 31, 2017 I test my caravan and journey with mine without issue. All it does is drop the voltage by creating a load. The starter motor would do the same damage if it was a problem. Hank Quote Link to comment Share on other sites More sharing options...
