Harfud Posted April 15, 2017 Report Share Posted April 15, 2017 My 2012 Dodge Journey 2.4 liter will turn over but will not start have replaced both cam position sensors and crankshaft sensors and put a new battery in it but still the car will not fire any suggestions on what to do next Quote Link to comment Share on other sites More sharing options...
Hankster Posted April 15, 2017 Report Share Posted April 15, 2017 Any check engine light? Codes? Throttle light? Quote Link to comment Share on other sites More sharing options...
Dusty256 Posted April 15, 2017 Report Share Posted April 15, 2017 check for codes , check fuel preasure , check for spark , fuel injectors . fuses . Quote Link to comment Share on other sites More sharing options...
Harfud Posted April 15, 2017 Author Report Share Posted April 15, 2017 On 4/15/2017 at 1:10 AM, Dusty256 said: check for codes , check fuel preasure , check for spark , fuel injectors . fuses . Expand Yes did all that no error codes has fuel, spark, checked fuses all good. Ran fine the day before after changing the crankshaft sensor came back to Illinois from Wisconsin parked in garage tried to start next morning and only turns over Quote Link to comment Share on other sites More sharing options...
Harfud Posted April 15, 2017 Author Report Share Posted April 15, 2017 Check engine light is on though Quote Link to comment Share on other sites More sharing options...
Dusty256 Posted April 15, 2017 Report Share Posted April 15, 2017 Could be a bad from stock sensor, known to happen .. Quote Link to comment Share on other sites More sharing options...
Harfud Posted April 15, 2017 Author Report Share Posted April 15, 2017 Put another new crankshaft sensor in today Quote Link to comment Share on other sites More sharing options...
jkeaton Posted April 15, 2017 Report Share Posted April 15, 2017 What's the code from the CEL? Quote Link to comment Share on other sites More sharing options...
Harfud Posted April 15, 2017 Author Report Share Posted April 15, 2017 No codes Quote Link to comment Share on other sites More sharing options...
OhareFred Posted April 15, 2017 Report Share Posted April 15, 2017 Did something get knocked off? Why did you change the cam and crankshaft sensors to begin with? Try clearing the mil with your code reader even though there are no codes. Try disconnecting the battery for 30 mins..... Quote Link to comment Share on other sites More sharing options...
Harfud Posted April 15, 2017 Author Report Share Posted April 15, 2017 I replace the crankshaft sensor because it came up with the area code in the car was dying off once replaced it ran fine from Wisconsin Dells back to Illinois parked at that night next day got into it will not start so I went and replace the camshaft sensors just to be on the safe side still having the same problems this morning got up went out checked it turn the car on you can hear the fuel pump whining constantly did not stop Dodge that the fuel pump is probably fine but it's probably a relay switch which I cannot find if you have an idea where it might be let me know Quote Link to comment Share on other sites More sharing options...
Dusty256 Posted April 15, 2017 Report Share Posted April 15, 2017 have you get the fuel preasure on the fuel rail ?. sounds like the pump is not building pressure . Quote Link to comment Share on other sites More sharing options...
jkeaton Posted April 16, 2017 Report Share Posted April 16, 2017 On 4/15/2017 at 2:25 AM, Harfud said: Check engine light is on though Expand If the CEL is on, there are stored codes. OhareFred 1 Quote Link to comment Share on other sites More sharing options...
PGRChaplain Posted May 5, 2017 Report Share Posted May 5, 2017 Harfud, did you get it repaired? My 14 is at the Dealer, same problem. Failed to start 4 times in a week. It started yesterday and I drove it to the Dealer. They had to push it out of the service lane. Went to diagnose it today, started fine the 16 times they tried it....... Quote Link to comment Share on other sites More sharing options...
PGRChaplain Posted May 6, 2017 Report Share Posted May 6, 2017 Yesterday was day 3 at the Dealer. Won't start for me, starts fine for them, Grrrrrrrr...... Quote Link to comment Share on other sites More sharing options...
