bbfans Posted April 17, 2017 Report Share Posted April 17, 2017 1. Replaced new battery at March 2017 as ran out of battery in last Winter more than 3 times. -------- 140 CAD 2. Replaced new battery case at the same time because of rust --------------120 CAD --second hand 3. Replaced the passenger actuator because of it keep blowing hot windy --------------250 CAD 4. Un-identify issue about hand-free system yet , the system stuck on loading .....process, un-connect battery can make it work few hours , the issue is still reproducible at next times .----------------------- dealer said replaced new hand-free system will cost 700 CAD. If I have another changes I rather than choice one Japanese or Germany car . :-( Quote Link to comment Share on other sites More sharing options...
bbfans Posted April 17, 2017 Author Report Share Posted April 17, 2017 (edited) The same issue Edited April 17, 2017 by bbfans Quote Link to comment Share on other sites More sharing options...
bramfrank Posted April 17, 2017 Report Share Posted April 17, 2017 42 minutes ago, bbfans said: The same issue What vehicle is that photo from? Because it certainly isn't from a Journey. And your BT issue is likely the module itself, unless you've blown the USB controller. Simple enough to tell . . . if you can play MP3s from a USB key while the BT is loading then it is most likely the module. The module is located under the dash, above the steering column. You can buy modules for about $300 IIRC jkeaton 1 Quote Link to comment Share on other sites More sharing options...
