brunosoares Posted April 19, 2017 Report Share Posted April 19, 2017 Hi guys, one of my sensor stop working but my Journey is on warranty and it was replaced. The mechanic told me that the sensor was changed and reprogrammed. So that is my doubt because my warranty is going to end. In future, the TPMS sensor needs to be reprogrammed? I saw some sites that says no programming needed, only change TMPS, Is that true? Thanks. Quote Link to comment Share on other sites More sharing options...
jkeaton Posted April 19, 2017 Report Share Posted April 19, 2017 As long as you are still under warranty and the dealer installed OEM parts, your warranty should remain intact. brunosoares 1 Quote Link to comment Share on other sites More sharing options...
bramfrank Posted April 19, 2017 Report Share Posted April 19, 2017 TPMS sensors in 2011 and later Journeys (can't speak for older ones) do not need to be programmed - they are auto-learned. brunosoares and 2late4u 2 Quote Link to comment Share on other sites More sharing options...
brunosoares Posted April 19, 2017 Author Report Share Posted April 19, 2017 So, in this case, if other crash for example, just I need to buy a new one and install in car. My Journey is 2013. Is there any vendor that you recommend that works fine and don't need to be programmed? Thanks for help! Quote Link to comment Share on other sites More sharing options...
larryl Posted April 19, 2017 Report Share Posted April 19, 2017 you just have to make sure they are the same Hertz?? cycle eg 433hz but there are plenty on Ebay and they pick right up Quote Link to comment Share on other sites More sharing options...
