Turn Engine Off when Fob is out of Vehicle
There isn't, and for good reason.
If the FOB sensor should fail while the vehicle is underway the car would shut down, potentially endangering the occupants.
So if you get out of your vehicle with the engine running and you drop the FOB or someone drives away without you the vehicle will chime and post a message about the FOB not being detected or out of the vehicle to warn the driver, but it will not shut down.
