Throttle body/pcv valve
Not sure if you solved your problem or not but ask the dealer to check your software and upgrade if necessary. Sometimes emission systems can be a little over active. If they state that it is normal then ask them to put it in writing so that when/if it does cause a problem you have paperwork stating that the excess oil in the throttle body was described as "normal"
