seuadr Posted May 25, 2017 Report Share Posted May 25, 2017 Hi, I've searched the manual and scoured the web (perhaps with the wrong search terms?) for this... When i try to search here the website just crashes over and over so i will just ask - what tread depth is "ok" for a replacement tire on the AWD? For instance, subaru says as long as it is within 2/32nds the replacement tire is not going to create any issues with the AWD system. I am sure that dodge has a similar specification, but i have yet to find a specific number. Thanks, Jared Quote Link to comment Share on other sites More sharing options...
2late4u Posted May 25, 2017 Report Share Posted May 25, 2017 your best info would come from the dodge dealership,good luck with what ever you find out..... Quote Link to comment Share on other sites More sharing options...
seuadr Posted May 25, 2017 Author Report Share Posted May 25, 2017 21 minutes ago, 2late4u said: your best info would come from the dodge dealership,good luck with what ever you find out..... Thanks, i tried a couple dealerships that were more than happy to sell and install 4 new tires, but none of them had any clue about depth. I ask because the current tires are between 8 and 9 32nds and as far as i know new tires are 10/32nds so, theoretically i may be able to just replace the one tire. Quote Link to comment Share on other sites More sharing options...
2late4u Posted May 25, 2017 Report Share Posted May 25, 2017 i assuming you have the 17 tires, try going with a used tire we have shops that have 3/4 tread ($45) and 1/2 tread ($35) mounted and balanced i have bought both at times for my daughters mail vehicle with no problems. or take the chance and go new....good luck Quote Link to comment Share on other sites More sharing options...
