evgeny_a Posted November 16, 2009 Report Share Posted November 16, 2009 Hi Is anybody know how oil cooler look like and where it is suppose to be installed? How to find it in the vheicle? is any indicator to swey control? Thanks Quote Link to comment Share on other sites More sharing options...
crunkfrunk Posted November 17, 2009 Report Share Posted November 17, 2009 there would be maybe a combination of flexible and hard lines running from the transmission to the radiator, you are talking about a transmission oil cooler right? Beucase some cars do have engine oil coolers like my Bonneville Quote Link to comment Share on other sites More sharing options...
larryl Posted November 17, 2009 Report Share Posted November 17, 2009 HiIs anybody know how oil cooler look like and where it is suppose to be installed? How to find it in the vheicle? is any indicator to swey control? Thanks The eng oil cooler is hooked directly to oil filter housing on my RT Quote Link to comment Share on other sites More sharing options...
evgeny_a Posted November 18, 2009 Author Report Share Posted November 18, 2009 The eng oil cooler is hooked directly to oil filter housing on my RT is anybody have a pictures of oil cooler? how is sway control working? - any warning lights? Quote Link to comment Share on other sites More sharing options...
Sam Posted November 18, 2009 Report Share Posted November 18, 2009 is anybody have a pictures of oil cooler?how is sway control working? - any warning lights? For the sway control, I don't think there is a light. And here's how it works: Trailer Sway Control[1] (TSC) senses trailer sway and takes action by automatically applying the right amount of braking to maintain control. And look at the video here: http://www.dodge.com/en/2010/journey/performance/towing/ Quote Link to comment Share on other sites More sharing options...
RedRT Posted November 25, 2009 Report Share Posted November 25, 2009 For the sway control, I don't think there is a light. And here's how it works:And look at the video here: http://www.dodge.com/en/2010/journey/performance/towing/ My RT didn't have the tow package when I asked the place where I had my hitch installed they said they didn't have engine oil cooler only a transmission oil cooler so they installed that. Do I need a engine oil cooler too? Quote Link to comment Share on other sites More sharing options...
Sam Posted November 25, 2009 Report Share Posted November 25, 2009 My RT didn't have the tow package when I asked the place where I had my hitch installed they said they didn't have engine oil cooler only a transmission oil cooler so they installed that. Do I need a engine oil cooler too? No, the transmission oil cooler will be enough. Quote Link to comment Share on other sites More sharing options...
evgeny_a Posted November 26, 2009 Author Report Share Posted November 26, 2009 No, the transmission oil cooler will be enough. in all of my old cars was installed transmission cooler for towing now i have factory installed oil cooler - is it replace trany cooler? how now protected gear oil from being oveheated? anybody have issues with overheated transmission after towing? <_< Quote Link to comment Share on other sites More sharing options...
Sam Posted November 26, 2009 Report Share Posted November 26, 2009 The factory installed oil cooler (in the tow package) is for the transmission. So if you have it, you should not have problem of overheat with the transmission. Quote Link to comment Share on other sites More sharing options...
evgeny_a Posted November 26, 2009 Author Report Share Posted November 26, 2009 The factory installed oil cooler (in the tow package) is for the transmission. So if you have it, you should not have problem of overheat with the transmission. in all specs it called not transmission cooler but oil cooler. i`m confused now... Quote Link to comment Share on other sites More sharing options...
Sam Posted November 26, 2009 Report Share Posted November 26, 2009 Sorry, you're right, it is an engine oil cooler. I was sure it was a transmission cooler, but no! Sorry! Now, yes, I would install a transmission oil cooler if there is not. Quote Link to comment Share on other sites More sharing options...
BigCountry Posted December 1, 2009 Report Share Posted December 1, 2009 I had much the same question and asked a bunch of places. I was told from Dodge directly, that the Journey comes standard with a transmission oil cooler. For the trailer tow prep, they have included the engine oil cooler. I was told that it helps keep the oil a more uniform temp at high RPMs and under a load while towing. For those that didn't get the option installed, there are kits available, that look very similar to the stock option used. Collar screws onto the oil filter recepticle and the oil filter screws onto the collar, lines run to a cooling block attached to the rad. It is about $150.00. Quote Link to comment Share on other sites More sharing options...
evgeny_a Posted December 1, 2009 Author Report Share Posted December 1, 2009 I had much the same question and asked a bunch of places. I was told from Dodge directly, that the Journey comes standard with a transmission oil cooler. For the trailer tow prep, they have included the engine oil cooler. I was told that it helps keep the oil a more uniform temp at high RPMs and under a load while towing. For those that didn't get the option installed, there are kits available, that look very similar to the stock option used. Collar screws onto the oil filter recepticle and the oil filter screws onto the collar, lines run to a cooling block attached to the rad. It is about $150.00. [/quot/] May be transmisssion cooler that caming with tow prep. a liitle bigger then original? How to prevent overheating oil in transmission when towing? Even we cant check condition of transmission oil to prevent tranny damage? Quote Link to comment Share on other sites More sharing options...
Mysty2 Posted April 22, 2015 Report Share Posted April 22, 2015 I am a little confuse! If I have the Tow Prep Group and engine oil cooler, do I need to install a transmission oil cooler also??? Quote Link to comment Share on other sites More sharing options...
