Window washer fuse location
Sandfox4
Usually the same fuse that handles your wipers handles your washer pump (not always). I am curious if you are hearing anything (from the pump) when you push the washer switch. I had the thin hose clog up on another car. In turn, it clogged the sprayer and I was not getting any fluid on the windshield. Mechanic friend of mine told me to remove the hose and sprayers, and let them soak. After a day of soaking it all worked again.
If you are not hearing the pump at all, you may need a new pump.
  • 2 years later...
Hello everyone, sorry for recover this old post but i was wondering if you were able to fix the issue since i’m having the same and i’ve already changed the washer pump. Did you fix it changing the wipers fuse? The only think that i’ve found is that it might be the accessory relay.
Thanks!
