2013 Dodge Journey reverse tail light
A little helpful hint for those who seem to have issues even after replacing the bulbs . So I replaced the bulb  several times in my back left reverse tail light with no success. On the rear door on the upper left hinge there is a cased wiring which feeds the back door panel. Pull back on the protective casing and look at wiring. In my case there where 4 wires broken . These wires are colour coded and should be easy to strip back and add a splice  in. Hope this helps people save money. Not the most attractive fix but efficient.
  • 4 years later...
Thanks that would of never crossed my mind to look there. This saved my inspection that is due tomorrow.
  • 1 month later...
  • 1 year later...
