Scott Campbell Posted August 15, 2017 Report Share Posted August 15, 2017 A little helpful hint for those who seem to have issues even after replacing the bulbs . So I replaced the bulb several times in my back left reverse tail light with no success. On the rear door on the upper left hinge there is a cased wiring which feeds the back door panel. Pull back on the protective casing and look at wiring. In my case there where 4 wires broken . These wires are colour coded and should be easy to strip back and add a splice in. Hope this helps people save money. Not the most attractive fix but efficient. Schutzy8, Armando G, 2late4u and 3 others 1 5 Quote Link to comment Share on other sites More sharing options...
km-04 Posted August 15, 2017 Report Share Posted August 15, 2017 Thanks for the tip. Quote Link to comment Share on other sites More sharing options...
OhareFred Posted August 15, 2017 Report Share Posted August 15, 2017 This is a known problem with the DJ. Can cause everything from bulbs not lighting to door lock malfunction. Very nice shot of the problem area. Not always clear when being described. jkeaton and Ezpeezy15 2 Quote Link to comment Share on other sites More sharing options...
Armando G Posted August 16, 2017 Report Share Posted August 16, 2017 Great tip and thanks for the included pic. Another perfect reason I like this site, helpful hints that will inevitably save someone time and money. km-04 1 Quote Link to comment Share on other sites More sharing options...
jkeaton Posted August 16, 2017 Report Share Posted August 16, 2017 Awesome! Quote Link to comment Share on other sites More sharing options...
Schutzy8 Posted June 30, 2022 Report Share Posted June 30, 2022 On 8/15/2017 at 7:09 PM, Scott Campbell said: A little helpful hint for those who seem to have issues even after replacing the bulbs . So I replaced the bulb several times in my back left reverse tail light with no success. On the rear door on the upper left hinge there is a cased wiring which feeds the back door panel. Pull back on the protective casing and look at wiring. In my case there where 4 wires broken . These wires are colour coded and should be easy to strip back and add a splice in. Hope this helps people save money. Not the most attractive fix but efficient. Thanks that would of never crossed my mind to look there. This saved my inspection that is due tomorrow. Quote Link to comment Share on other sites More sharing options...
Schutzy8 Posted August 11, 2022 Report Share Posted August 11, 2022 Thanks I never would that to look there. I appreciate the info with the pic. Quote Link to comment Share on other sites More sharing options...
Ezpeezy15 Posted September 18, 2023 Report Share Posted September 18, 2023 I will be checking this today. I noticed this weekend that I have one reverse light staying ON. Quote Link to comment Share on other sites More sharing options...
