Outinthewoodsnf Posted August 22, 2017 Report Share Posted August 22, 2017 Hi, I've just recently replaced the 3.6 engine in my 2011 Journey AWD, and the light in the dash for the traction control has been on every since.... I'm wondering if I may have missed a plug when reattaching all the wiring.... Does anyone know what the traction control plugs into? Quote Link to comment Share on other sites More sharing options...
ltdjourney Posted August 22, 2017 Report Share Posted August 22, 2017 On 8/22/2017 at 3:05 PM, Outinthewoodsnf said: Hi, I've just recently replaced the 3.6 engine in my 2011 Journey AWD, and the light in the dash for the traction control has been on every since.... I'm wondering if I may have missed a plug when reattaching all the wiring.... Does anyone know what the traction control plugs into? Expand Was the engine from another journey and did you use same transmission from you journey or ?? Quote Link to comment Share on other sites More sharing options...
Outinthewoodsnf Posted August 22, 2017 Author Report Share Posted August 22, 2017 I bought it from a scrapyard,,, not sure what it came out of but it looked the same and is a 3.6 vvt... They said only 49K on it.... I used my own .transmission Quote Link to comment Share on other sites More sharing options...
2late4u Posted August 22, 2017 Report Share Posted August 22, 2017 does it run okay other then the light??? Quote Link to comment Share on other sites More sharing options...
Outinthewoodsnf Posted August 23, 2017 Author Report Share Posted August 23, 2017 She lost power a couple of times on my Gf,,,, I pulled one of the front bearings today and found that the inside part of the bearing that the abs sensor reads was torn up by debris.... Thinkin this might cause it...I removed the abs fuse and I'm hoping that it will be ok.... The service AWD light is on but maybe that's because the ABS is disabled? Quote Link to comment Share on other sites More sharing options...
jkeaton Posted August 23, 2017 Report Share Posted August 23, 2017 On 8/23/2017 at 12:45 AM, Outinthewoodsnf said: She lost power a couple of times on my Gf,,,, I pulled one of the front bearings today and found that the inside part of the bearing that the abs sensor reads was torn up by debris.... Thinkin this might cause it...I removed the abs fuse and I'm hoping that it will be ok.... The service AWD light is on but maybe that's because the ABS is disabled? Expand Yes. The AWD/ABS/Traction control all work together. Quote Link to comment Share on other sites More sharing options...
Armando G Posted August 23, 2017 Report Share Posted August 23, 2017 Wait...I'm still stuck on, "She lost power a couple of times on my Gf...". I assume that this was a good deal if that doesn't concern you as much? Quote Link to comment Share on other sites More sharing options...
Outinthewoodsnf Posted August 23, 2017 Author Report Share Posted August 23, 2017 Journey was bought new,,,, definitely wouldn't call that a deal..... The motor doesn't seem to be the issue.... Looks like the traction control was cutting power to the engine because of a damaged part of the bearing that is read by the ABS sensor.... No trouble today with the ABS fuse out.. When I eventually replace the bearing, I'll put the fuse back and see what happens.... I miss the days when a computer didn't control the whole car. Quote Link to comment Share on other sites More sharing options...
Armando G Posted August 23, 2017 Report Share Posted August 23, 2017 On 8/23/2017 at 9:25 PM, Outinthewoodsnf said: I miss the days when a computer didn't control the whole car. Expand AMEN to that. Sorry, I guess I misunderstood. It does seem crazy that other than just give you the warning, the ABS sensor would cut out the car. Better safe than sorry I guess. Quote Link to comment Share on other sites More sharing options...
