When coming to a stop quickly engine cuts out
When coming to a stop quickly engine cuts out and symbol appears. Usually if I start the cat again it drives normal but other times it cuts out straight away. I took the car to the mechanic and he found that the turbine / some filter to the turnbine had a hole in it and that was cause the  engine to stall due to low revs. He repaired it and all seemed fine till today wjennthhe same thing happened.
